Missing smileys
When I joined the forums a few months ago, we had a lot of smileys to choose from. Following the upgrade, they were missing for a while. Now, there back! But it seems like a few of us don’t have acces to all of them. Personnaly, I can see 49, but can use 56 (can’t see the row with grumpy, but still can use it)… Like I said, some of us can and the others can’t… I was just wondering why… browser problems maybe?
Cheers!
Edit: If other buddies have the same problem , please make a post here [;)]
[#ditto] plus “t”.
My “troll” won’t show up and just barely the tops of the bottom row above the troll.
60
I miss the the last three rows when the window opens, but the cursor “up” and “down” buttons scrolls through them all. My guess is the new software the forum uses is either not up to standards, or the browsers we use aren’t. I’m posting this with Firefox 2.0.
I’m using IE 7 and am having no problems. [troll][yuck][|(] All work. I have no ‘up / down’ cursoe, just have to ‘click’ beside all the icons and move it down using the cursor. It works now, so I’m not complaining.
I have the same problem as not being able to see them all but I click in the bottom right corner on the 100% and select 75% and them I can see them all. Although at the moment my whole toolbar is missing!!!
I too am missing smileys. When the new window opens to select smileys, it appears that some bottom rows are missing. I cannot scroll down or resize the window to see what they are.
[#ditto]
my icon display is 7x7 , no way that i know of to expand it
I can’t resize the window either. That’s why I shrink the smileys. You might have to squint a little tomake thm outbut they are all there.[troll]
I am also having a problem. It will not let me resize or drag the corner at all.
I know, I know… I don’t know why the popup windows were originally coded to not allow them to be resized. It’s on my list but it’s a rather long list. [B)]
If you’re using IE7, just go to the bottom right corner of the smiley popup and change it to 75% on the zoom. You’ll have to do that each time you want to access the lower buttons, but that’s a work around until David can get to fixing that. [:)]
Thanks David. What else is on the list we may not be aware of? Trying to catch us by supprise, are you. [%-)]
I’m sorry, sir. That information is CLASSIFIED. [(-D]
Thanks David
I just posted an update to fix a couple of items on the forum.
  • The smiley window is now be scrollable & resizable.
  • The images window is now wider but just in case it is also scrollable & resizable.
  • The font size in the posting editor was increased a tiny bit.
  • The strikethrough is working (has for awhile).
  • I added in a compression script that should make the posting page load much quicker.
  • When posting a url using brackets, it will work with or without quotes around the url. With quotes was not working after the new posting editor was added.
Let me know if your smilies are all there now. [;)]
EDIT: I uploaded a cheat sheet with all the different smilies with their corresponding bracket code.
Wow, good job David. I even got this guy back, [troll].
Thanks again for the good work you do. And the rest of the staff as well. [#toast]
60
Awesome! Thanks David! [#toast]
[party] Awesome job David! Thanks!
Thanks DV ,[tup]
Thanks David. [tup]
