if I thought I was mad doing the Wespe with a load of add-on PE and tracks, I am now starting this… full interior T54-2 1949… I hope to be able to do it justice, some of the other interior builds I have seen is what are driving me on…
so far I have just opened the box and panicked… need to label all the sprues I guess before starting
Yeah, it’s a pile of work. I started on MiniArt’s T-44 with the interior years ago and it’s still half-finished in the box. Sigh, another thing I need to pull out and finish. Thankfully the fit was pretty darn good, hopefully this one will be as smooth a build for you.
I facilitate Russian history classes from time to time, and planning a couple of new ones. Anyway i got into T-34s this past winter and have 12 or so of various scales including T-34/76 and /85 in 1/35 and 1/48 with complete interiors. Also a KING TIGER. i will get the Amusing Hobbies (?) T-72 with complete interior once i finish some shelf queens.
if you have the plastic clips that hold loaves of bread closed, they make great sprue markers. clip it on and use a marker for the letter. also wire desk top sorters for letters and files from an office supply store make good sprue dividers.
all marked up ready to go (apart from the 10 sprues of tracks, 8 of wheels and 6 of shells)… noted the interior paint colours and ordered the few I was missing
the modular nature is taking shape. I am adding parts with same colour to main bits, then will paint other parts on the sprue before attaching… so need to work out how to pay 8,345 shells (or however many)… the air pump(?) pipes broke in to multiple parts but are attached and hopefully wont be too visible
if you mean the wiring for the engine then no, not provided… some people to wire up the top as that is visible with the hatch open - haven’t decided if I will (may be too late now it is all glued together (not to the body tho)
I accidently melted the shells on my T-44 and ended up buying turned metal replacements. On the up side they do look way better than I could have painted them brass though.
Just about this time I would be cutting out the Hull, Transom and Sides for an off the wall Work Boat with that interior! With geared twin drives, driven off Both ends of the engine!
Hey Wayne, I painted the plastic shells with acrylic brass and hated the way they came out. So being a dum-dum I dunked them all in paint thinner to soak the paint off. Then forgot about them for a couple days. When I came back they were a big melted goopy stuck together mess. [:(DD]
The T-44 had a standard 85mm gun so they’re just regular turned brass 85mm shells. I believe the T-44 turret was retrofitted to the T-34 to make the T-34/85. So any 85mm aftermarket shells should do the trick. Biggest problem is I had to rebuild the straps etc around the shells.
progress…all still dry fitted. So far so good, just a couple of breaks but they are OK once in situ… really need to start painting - going to prime all grey, airbursh the large parts (sides/bulkheads/engine/floor) an dthen brush paint the detail…
