Micro set/sol
How soon after applying the the micro set should I be applying the micro sol? I am applying the decals over a dry future finish. Thanks
ICIT
The micro sol should be applied fairly soon after teh decals and micro set are applied. Read the directions of the bottle for specific instructions.[;)] if it is an area (compound curves, etc.) that will obviously needing micro sol, the sooner the better
Icit, I apply it right after I use a paper towel to soak up the excess setting solution/water, I feel the soon it is applied the better it will settle into the low areas. Just remember It will get somewhat wrinkly RESIT the urge to mess with it, that is how it is supposed to look while it dries. Good luck and have FUN!!!
James
Thanks guys, I am going to take advantage of the snow day and hit the bench.
ICIT
