micro set and micro sol how to use
i would like to know the best way to use these products as using for the first time
Decal solvents are a frequent thread on the “decals” forum, so if you do not get the answers you are looking for here, I urge you to try that forum.
That said, I start with the micro set. It is pretty benign. Only if the decal does not settle down well do I resort to a solvent (like Micro Sol). Decal solvents are pretty mean stuff, so once you apply them you have to leave the surface alone until it is completely dry. So- summary, start with Micro Set, only if that doesn’t work go to the solvent. Use as little as possible, and use great care.
Micro set,the blue bottle is brushed on the area where the decals going,it is also applied on top after the decal sets some
Micro sol,the red bottle is stronger,it can be applied on top of the decal to help it song down over raised details,or panel lines after the blue bottle stuff
And then if your decal is really really stubborn use walthers solveset on it and don’t touch it what ever you do! I’ve been using it alot on my last 2 models. Good stuff but hot!
John
It is a bit frightening to watch your decal get all wrinkled up shortly after you apply a solvent. That’s normal. Just don’t touch it, walk away and leave it alone overnight. You will be pleased at how good it looks the next morning!
Be careful! Not all decals are equal. Tamiya decals usually don’t play well with Micro Sol, and I’m assuming other solvents.
tagged to subscribe to this thread… Bought this product but haven’t used it yet.
I wonder if GerryM is even interested in our answers,I mean no thank yous or any response.
Just one of my pet peeves on the forums,people answered you,just say thanks
It’s important to note that when using a decal setting solvent, the surface to which the decal is to be applied must be glossy. This means that if the final finish is flat, you must apply a clear gloss to the model, apply the decals and then apply a clear flat finishing coat.
As noted above, when a setting solution is applied to a decal, it wrinkles and shrivels. If the underlying surface is flat (ie. not glossy), it will impart too much friction to allow the decal to settle itself and smooth out as the setting solution dries.
