How do you make windows out of this stuff.
scott
scott
I haven’t tried it yet but from what I’ve read you put a certain sized drop on the end of a pin or needle, touch the drop to the inside frame of your window and run the drop along the frame moving the pin or needle closer to the certain of the opening until the window film fills the opening. Then pull the needle or pin out and let the film dry. It’ll appear withish while wet but drys clear. Hope this helps.
