Method for modeling cowl vents
I’m building a 1/48 scale PT boat. Cowl vents are the metal vents that allow air to flow down into the lower parts of the boat or ship. I would like to have these hollowed out so that they appear more realistic. The kit came with cast metal cast cowl vents and trying to hollow those out was hopeless. The metal is too soft.
What I’ve tried is to cast the cowl tops in resin, drill up through the base until I break through, then shape the concave part of the vent. That worked, but I think I’m still a ways from where I would like to be. For one thing I’m having trouble coming up with a good method for shaping the inside of the cowl vent to get it thin enough to where I think I’d be happy with it.
I hope this makes sense. If anyone has any ideas on this subject I’d be greatful.
Thanks all
Dave
Cowl vents are available in the catalog in Blue Jacket ship models. Also, H & R products sells some cowl vents.
I gave up modeling a 1/200th scale WWI era US battleship because of the cowl vent problem.
If you can come up with some good cowl vents then you could start your own cottage industry selling casts of the things.
Try contacting some of the cottage industry manufacturers, like the Scale Shipyard
http://www.scaleshipyard.com
I know they have a line of 1/48 scale cowls for Tugs cast in resin that might be useful for your project.
Another alternative would be to carve a solid cowl in two halves and heat or vacuum form over it to mae a hollow plastic unit. That would be my approach if I could not find a ready made part. Dean’s marine uses this technique on its kits, and I have built 1/96 scale WWI era cruisers and destroyers with vac formed plastic vents - lots and lots of them!
HTH
Kurt
