Meng t-90 a Tracks
hi all,
need help built a T90A from Meng but th track is like 500 parts to build. Can someone please recommend a pre built track I can use for this model. There are 81 treads per side plus the 81 track guides and 162 outer tabs to hold it together. My old eyes cannot seem to get it straight.
thanks
OBA- Old Bad Ass
Sector 35:
https://hobbyterra.com/product_info.php?products_id=4262
Not cheap, but the white metal tracks come 90%+ pre-assembled.
They actually went together pretty easy for me,pretty relaxing.I just hate spending money on AM tracks,especially since they were just beautiful.
I even added the parade ground pads [:D]
thanks. Those are expensive—i will give it a shot and see if i can get the tracks built under a magnifying glass
Ok is this normal with building tracks instead of the pre built in my Tamiya kit. The Meng tracks are 800 pcs to built the track- 162 link, 162 guide, 328 2 pcs to hold each link and a 162 center pcs to fill the gap between each link. four hours later two tracks built!
This has now turned into my mule! I started it and then put it back in the box. Upon re-opening I realized I screwed up the machine gun badly, missing some of the parts. So i just pieced it together and gave it a few coats of Russian green by Vallejo. So now I’m going to experiment with filters, grime mud, etc
