While at Loews buying up their discontinued MEK , I purchased a 3M respirator rated for MEK and heavy rubber gloves.
I already own goggles and a face shield .
Won’t be working with it till spring as I need to set up a paint booth for ventilation, make assembly jigs, buy 4 view plans , make armor plate hull patterns for cutting sheet plastic.
Much obliged about the info.
I will be reviewing chemical data sheets and FSM archives for MEK safety suggestions.
We are a tenant on an AFB. The AF has pretty much discontinued it’s use but, since our TMs call for it with no suitable sub, we stock it but have to follow their rules. It gets pretty stupid…
At the bench, I don’t have vapor problems and have started wearing eye protection pretty much all of the time I am working with chemicals and pointy things after a couple of close calls
I think you should be able to find it at HOBBY LOBBY .I have laminated with it, turned odd amounts into filler putty by dropping chopped sprue in it ad infinitum .I think you wouldlike it as the odor factor is slight .As for safety glasses , well , I work a lot of brass for a client and I don,t want to have to deal with chips in the eyes which have contacts on them .The gloves are another matter now . I do use the gloves that my doctor recommended for me and they are great -No finger marks on stuff ! The TESTORS glue bottle is kinda tall so put a 1/25 scale truck tire around it to prevent spills . And don,t use that MEK anything .I hed some left from a fiberglass job and knocked it over , Before I realised it I had a ruined GEARING hull ! Spare hulls aren,t an easy thing to accumulate!! Well , good luck and catchya later----tankerbuilder .
