Me 210 intirior
Hi, i am confused abou the intirior of the Me 210. I know the cockpit is dark grey, but is it not supose to be rml grey like most merman aircraft. Also what colour are the gear bays and stuff. If you know anything about this plane i would, aprisiate the info thank you.[;)][B)]
Basic cockpit color would be RLM 66 Schwarzgrau (very dark grey). Gear bays would usually be RLM 02 Grau (medium grey-green).
Rick
Using Testors Gunship Gray out of the spray can is a nearly identical match for the interiors of Luftwaffe German aircraft, including the Me-210. My Dad was the one that discovered that. After using the old Aeromaster color for the cockpit of one Me-109, and just for a kick, spraying another with the gunship gray, it was practically impossible to tell the difference! Just a suggestion and I hope it helps.
thank you for your help iwill use the tips well
Tips I didn’t know I needed!! I’ve got a BF 110G-2 in the closet maybe i’ll get to it soon. Avoiding that splinter camo 'cause i’ve never done it.
