first time posting. been back in the hobby for about a year and half doing mostly cars and thought i’d try to do a tank. In the color scheme it calls for matt black and matt brown. i am having trouble finding these colors that arent spray. Can someone describe what the “matt” means? Is it referring to sheen, is there substitutres for it?
Yep it’s the sheen, matt is flat. If your using acrylic Tamiya then the paint is already flat. If you are using a enamel paint or other gloss color you can hit it with a clear flat to take the shine off of it.
Not quite that simple. Tamiya paints come in gloss, semi gloss, and flat (or matt) finish. The paints with a X prefix are gloss. The paints with an XF prefix are flat.
Which tank are you building because specific nationality vehicles are best painted with certain colors. Black is pretty generic, but brown has a huge range of tones and shades.
M41s mostly saw service in overall Olive Drab, with the exception of a few smaller countries late in the tank’s service life. What is the brown for? Also I might ask as to where you are located, and what paint brands that you have access to there?
For tires, rubber road wheels, etc, I like to use Tamiya’s matte NATO Black as the base color. It’s more of a dark charcoal gray. I think it looks better in scale, than straight-up black.
To some extent you can vary the sheen of paints with varying the thickness and pressure of an airbrush. Using higher pressure for gloss paints, or doing a very dry/thin application will tone down the sheen. Applying a very wet coat of flat paint will result in a semi-matt appearance.
If you thoroughly stir flat/matte black paint it will come out flat/matte. I don’t see how a flat black or matte black paint comes out semi gloss sheen if applied very wet unless you’re spraying heavily.
It’s pretty clear to me that this is all beside the point for the OP. Their question was more basic, how to find a bottle of each of two colors labeled in model instructions as “matte black” and “matte brown”.
Not “what makes paint matte”.
In other words, a color question, not a finish question. The answer is that those areas of his model labeled to be painted as such are the road wheel rubber and the tool handles.
