Masking Canopies
I was just wondering if any of you guys could help me understand so I could complete a F4U-4 canopy.
I need to paint the the frame of the canopy and have not had much luck in the past. When masking the canopy, should I cover the entire thing. Then should I trim off where the frame is and then paint. I am afraid I will either trim to deep and cut the canopy or after removing the mask I will find that I missed the frame altogether.
Any suggestions will be welcome.
Thanks.[8]
Try this … http://www.swannysmodels.com/Canopies.html
[#ditto]
I’ve used Swanny’s method, although my only “complaint” is tight curves. Cutting the masking tape into very small strips is a great strategy. I just masked my 1/48 F-4E canopy; the top of the middle secion of the windscreen was tough, but I “got-r-done”.
I think Swanny’s is the best so far, but not everyone agrees.
[#ditto]
I’ve used most other methods, and I agree, the one detailed by Swanny’s is the best. I do sometimes use a ‘faster’ variation method on simpler frames where theres pretty much only horiztonal & vertical frames. I mask so only the vertical frame as exposed and paint them. After a good period for drying, remove the masking and mask only for the horizontal.
This method takes ‘longer’ in absolute time, but is much shorter in actual masking time.
I started using Bare Metal foil for masking canopies and been having great results. I masked my Tamiya Beaufighter in about 15 minutes. I tried Parafilm and wasn’t happy with the results. Swanny’s method really didn’t work for me.
I think bare metal foil would get expensive… I use the tape method, and a bit of advice for you is MAKE SURE YOU BURNISH IT DOWN REALLY GOOD WITH A TOOTHPICK! I almost had a catastrophy with my P-47 but i successfully scraped the bad paint off.
Thanks to all for the replies. I checked swanny’s page and it really helps. I have also been thinking of the BMF route but, I must agree it could get expensive quickly,all for saving those pennies where I can.
Once again, thanks.
[:)][:o)]
I agree, it is expensive.
But the way I see it is compared to the ready made paint masks it’s really not so pricey.
Yeah, I’ve just started using Swanny’s method. It takes more time, but I have had severe problems with BMF residue being left on the model. It isn’t fun to get off.
I used to use masking tape… then Pixilator turned me on to the 3M frosty magic tape… it’s a little easier for me because you can see through it a little better. I’ve always had trouble in this area… I think mainly because I build 72nd and it’s sooooooo small. I just used some liquid mask and it work so, so. The key is: whichever material you use just go really slow and be really patient… when I get frustrated I have to just put it down for a while so I don’t ruin it.
