marder 3 interior and winter wash?
Hi. Does anyone know if winter wash was applied in the fighting compartment of a marder 3?
Since supplies of lime white-wash were not always plentiful, indeed sometimes scarce or not available at all, it’s use was generally restricted to the exterior portions of vehicles. It is not uncommon to see photos of vehicles with only the front and sides covered with white-wash, while the roof and rear of the vehicles were left bare to conserve supplies. Bed sheets and even scribbled lines of chalk were often used as substitutes when white-wash was not available.
Loepold is correct, in all my panzer color books I did not see any interiors painted whitewash, paint was in to short supply.
okay. Thanks a lot, guys.
i think they put covers over the fighting compartment in the winter, to keep the wind,rain and snow away from the troops
Whitewash was thinned with water when used. It was usually spread on with a straw broom or rags, but the crews were not that careful in applying it.
The interior of open topped vehicles sometimes had whitewash ‘dribbles’ from where the brush was pushed up the side to the top of the armour plate. This was the only time the interior got ‘painted’ by crews. The whitewash wore off quickly, and any dribbles on the rear access panels were quickly worn away or covered in mud and slush.
As the good Captain has said, many crews used canvas tarps or canopies to ward off the cold and bad weather; if they didn’t they improvised. Personally, I prefer to see all the nice detail in the vehicle compartment and would hate to cover it up with a canvas.
There are many pictures of whitewashed vehicles where the bottom edge of the canvas has traces of whitewash from where it was spilt when being applied or where the crew actually intended to apply it. The canvas was flexible and bellowed out by wind. Usually the whitewash on the canvas was very quickly eroded by this movement, and the canvas should therefore show only traces of past whitewash unless you are depicting a dio scene where the wash is being applied.
Hope this helps
