evening all… I hope I dont bore anyone with these questions but since joining FSM I have been astounded by the generosity of everyone and the willingness to help even the most novice builder. I have been building models for a long time and after seeing the pics people post I feel like I just started. I have done box stock and some small kit bashes. The time has come to go to a new level and start trying some more complicated projects [:D]. My questions are, on most of the boxes it say says molded in plastic. Is that polystyrene and if so are there places to buy sheets of it? #2 What exactly is resin and is it hard to do? I have a project in mind for a 1955 Chevy that has been in its box for too long. I need to build a new chassis for the ideas I have and dont know where to start. I have my parts box and have been unable to use any of the spare chassis’ s that are in there.#3 what exactly is ALCAD and what is it for?I have seen it mentioned is several posts and always wondered. I want to thank you all again for reading and hope that I didnt offend anyone with my ignorance [:o)]. I am sure that I will have more questions later but I think that this should be enough for now Thanks again, Shane
Ok, I will see what all I can answer for you.
#1 - Yes, you can buy styrene in sheets. It comes in all sorts of thicknesses and you can also get just about any shape. Most shops have a rack of Evergreen or Plastruct of it.
#2 - Resin is stuff that you make a mold and pour in as a liquid and it dries hard. I belive the most recent copy of FSM has a basic how to on resin casting.
#3 - Alcad is some paint that you can use to simulate metal finishes with. You apply it on to a black base and when done looks very much like metal. I have not tried it myself , but I have seen the results and they look pretty impressive.
Chris, thanks for the help. More questions if you dont mind.#1 does that mean that the kits are polystyrene and were those the names of specific brands? #2 is making resin hard and would you recommend it for a somewhat newbie like myself? Thanks again for the help. Shane
[#ditto]
Welcome aboard, Shane! [#welcome] It is true, associating with such a fine group of modelers is very inspiring, and to be accepted on a level playing field, regardless of experience, is what makes these folks the BEST! [:)] So join right in and make yourself at home. [:)]
Take care,
Frank
Thank you Frank. Hope to do everyone proud.[:)]. Shane
Shane, to answer your most recent questions…
- Yes and Yes. The brands Chris mentioned are the most common and ususally found in most hobby / model supplies places.
- Resin is not hard to do but as with all chemicals mixes safety is paramount. Have a look at the FSM with the resin article in it and go for it. Remember to keep the place well ventilated and follow the makers instructions to the letter.
If you are unsure contact the local modellers club nearest you and there will be someone there who can advise.
After all that Welcome from me as well.
Enjoy your stay.
Cheers , Pete.
Welcome Shane, I think everyone answered your questions, so I won’t be too reduntant. However, make sure that when you sand any resin you wear a dust mask. The particles are very fine and can cause respratory problems. That is what makes resin the hardest to deal with. I try to do any resin sanding outside, as it is also hard to clean up without “contaminating” the surrounding area with it’s fine dust. Hope you enjoy your stay here at FSM!!!
Thank you all for the responses so far. More questions if thats okay. When using ALCAD is it best to spray or brush. I usually use an airbrush (Aztek…good luck so far, but judging from past posts thats still up for debate[:D]). If spraying what is a good ratio for thinning down? Also, should a gloss or a flat primer be used? Thanks again to all. I thoroughly enjoy this forum for all the wonderful folks… Shane
