Yes, it’s only wood… but a slice barely thicker than 1mm
can withstand being slammed against steel, for years http://surfpick.com
Lignum Vitae is also notorious for it’s poor adhesion properties.
You have to treat it with acetone, to epoxy it.
The wood needs no finish and will accept none.
It appreciates sanding all the way up to 2500 grit,
where it becomes more like a marble finish, than wood.
I’ve never done it, but primitive peoples used to make them out of porcupine quills, cactus spines, and bone all the time. I am familiar with lignum vitae and see no reason it wouldn’t work. Expensive bloody needle!
I once made a mountain out of a molehill, but the results were less then pleasing…
Ya know maybe it’s worth a try ? Lignum Vitae is also notorious for it’s poor adhesion properties.
where it becomes more like a marble finish, than wood. If it works in R&D I’m in for an investor.
