Making Progress on A6M2
Have basically completely assembled this kit in less than two nights. I was amazed at how simple it was yet with a decent level of detail. I am curious as to whether the decals in the kit are correct for a Pearl Harbor attack wave aircraft? Also what interior color should I use? I am also debating whether to build it wheels up or wheels down. What are your opinions on this?
What kit are you using.
Here is a link for paint colors.
http://www.j-aircraft.com/research/gregspringer/wem-review/wem-review.htm
Can’t help you with the markings.
From past experience, About the rasied or lowered landing gear. If you were going to mount it on a stand with a base, then I would build it wheels up. With this, you expose the stream lined aircraft. If you want it to sit on a shelf then build it wheels down. Also, with wheels down, there is a lot more work involved.
David
I am using the Tamiya A6M2
