Aside from a Glosscote or Future topcoat, has anyone had any success with additives to make flat acrylic glossy?
I read somewhere that you can mix Future with acrylic paint in varying proportions depending on the color (dark colors tolerating more than light colors). I’ve been experimenting with this technique myself using Model Master Acryl and have had some success, but I need more experimentation. I did find that light colors (I tried it with tan and white) worked best when spraying one initial flat coat first, then add some future to the subsequent coats. The tan came out quite glossy (a very shiny semi-gloss), but white didn’t come out very glossy at all (I was afraid to add too much Future). Quite easy to go transparent if you mix in too much Future though. The good news is that it didn’t seem to have any compatibility issues and layed down well.
Has anyone else had any luck with mixing Future in or any other additives to get a glossy finish?
What you are doing is adding a binder that produces a glossy surface. This also reduces pigment load (the paint will become more transparent and have less hide). As long as you don’t run into compatibility problems, that’s essentially the only drawback. In the case of some paints, a small addition of Future may also improve coating adhesion and durability.
Silicone oil is sometimes used as a gloss enhancing additive. I strongly recommend against trying this, because the amounts added are very small, compatiblility is more likely to be an issue, and the surface will be very difficult to overcoat with anything.
That makes sense, and I suppose that’s why a flat (undiluted, or very slightly dilluted) 1st coat worked best.
The Future also seems to thin the paint slightly.
I hadn’t considered the adhesion and duirability aspects. That’s a bonus. I always use a primer to improve these weak areas of Acrylic.
One other benefit I may have found is when I put the paint on too heavy (not that good with my double action yet), the Future seemed to level it out when it dried.
I’ve learned from experience, never put anything with silicone near paint or anything I wish to paint. I don’t even like the two words in the same sentance.
The acrylic polymer in Future has a very low viscosity. It’s initial cure is slow, then it accelerates to the point of tack-free, then slows down again to full cure in 24 to 48 hours. That explains your apparent thinning. I hope the chemist(s) who developed Future were hugely rewarded—they deserve it.
I’ve even heard of some people who add their own pigments to Future, essentially making their own paint. Even I’m not that crazy!
The amount of silicone we put in a test batch (about 1 quart to half a gallon) was usually on the order of one to two drops. That’s not much per 1/4 oz.
