Well, finally I’ve finished this model. Many stops and problems of different types but I am more than satisfied with the final result.
As I was saying during the process, it’s the first time that i’m looking for a finish in good condition, with minimal weathering effects, enough to give it some credibility.
To highlight the work of staging with water. I have used an unconventional technique, very hard work but I think the result is worth it. At first, i’ve modeled the whole sea scene in clay, which allows you to work without haste and design the image that i had in mind. Once the model was finished in clay, I made a two-component silicone mold (special for molds). Once the mold is made, fill it with a transparent bicomponent resin, stained with translucent tamiya acrylics. So far all good except for the “small” detail of wrong to use talcum powder as non-stick and clear, these were stuck to the resin. I had to cut and carve the entire surface of the water to remove the whitish layer of talc. After carving, sanding and polishing … the result is not bad.
As for the model, it also gave me some problems … especially in the final part when making the braces, something I had never done before.
Here are the photos of the model in its natural environment.
Wow, that’s outstanding! The model on a plain base would be exceptional on its own, but your base is a jewel as well. Thanks for describing your process to create it!
I agree with all the other compliments. It’s outstanding!
I would, however, pity the pilot who tried to either land or take off in that sea[:D].
Looking at some of your other aircraft models I’m even more impressed. That Devastator is simply devastating!! Superb work on all the models you’ve put on the link from your bio.
Italian floatplane fighters are so beautiful, and yours is no exception! Your construction technique for the base, plus the corrective work you carried out, is simply amazing! Well done.
Your water is so incredibly 3-D, I wonder if it has inspired someone to do a surfing diorama? With a shark under the wave, of course!
Yes, I always try to represent the plane in its natural environment and in conditions that I consider are dynamic and unconventional. The Devastator was my first “serious” project … jejejee i’m glad you like it.
