I want to make the M60A1 I was on in Desert Storm and I want it to have an interior in it. Does someone make an aftermarket interior? Verlinden makes the pack for it . Thanks for sharing any knowledge!!
I do not think there is an interior for an M60 series (any) tank. I know the driver’s hole from the M60A1/A2 kit is not accurate and very incomplete. Good luck in your search, I’d be interested in an interior set if one was available. I spent quite a bit of time in both a CEV and M60A3TTS.
Thanks Rob. If I find one I’ll drop you a line.
I checked AEFDesigns.com and they only had the engine compartment and back deck. No turret or driver interior.
haven’t found one yet.
IMO there are components from the M1 interior kits that you could use. Of course there would be some heavy modifications, but at least you have a starting point then.
