M60-ish, in between projects. Finished 1/24
Can’t help myself. While I realize “what-ifs” aren’t particularly popular here, I’m having too much fun not to share. Starting with the Academy Magach7 I stripped for parts recently, I realized I still have a metric ton of spares, partial kits and boxes of AM stuff that unless I get started on using soon, will end up in my stash forever. With that in mind, I started adding detail lost when I stripped the hull, and detail Academy didn’t try to do. I’m using the inaccurate swing arms, adding some better shocks and tensiioner linkage, and Abrams road wheels.
In other words, just having fun.
IMG_6569 by Russel Baer, on Flickr
IMG_6568 by Russel Baer, on Flickr
I did a whif a little while ago using a Merk1 turret on an M60 hull, so I’m kind of leaning towards staying with the M60A1/3 turret this time, but for sure IDF.
Unless anyone out there has an Academy Merk3 kit they wanna get rid of…
Doctor Tankenstein strikes again!!!
Nyuk, nyuk, nyuk… I did some more today, not enough to take ppics of though. And I found some air filter housings in a Dragon M60 parts kit that would have been perfect for Gimel, dang it.
Pic of the turret and basket, filter housings and some detail being added to the rear:
IMG_6570 by Russel Baer, on Flickr
I’ve got most of a Magach6Gal Batash kit (Academy) that I might use the turret armor out of, but thinking more likely something else at this point. Turret is an ESCI part, basket from the Gal Batash. I used swimming pool skimmer mest for the floor. It’s really too coarse, but it’s flexible and tough, glues easy.
Pool skimmer mesh, interesting. I’ll have to remember that!
Looks good!
You really make me want to bash some kits together.
This is only fueling the fire lol.
G- It’s a little over-scale, but very easy to use, doesn’t come apart like nylon mesh and is flexible.
Mike- It’s my favorite kind of modeling, can’t really say why.
More on what I guess I’ll call a Magach6D Gal. On the turret, I hogged out enough plastic to fit the Academy gunner’s sight, from the batash kit, got the AFV Club mantlet on and started the IDF-specific cover. On the nose, I have the access poet for the Gal FCS started, For the hull, I’ve got the fender extensions and brackets on (Dragon parts, tow lugs (DEF) and cleaned up some unnecessary holes.
IMG_6573 by Russel Baer, on Flickr
Lower hull/suspension is closer, final drives done and sprockets ready. I’m using old Tamiya T-62 sprockets and Friul Merkava4 tracks, which fit perfectly. Also on are bump stops from a Dragon M48.
IMG_6572 by Russel Baer, on Flickr
Too much fun!
Mantlet dust cover details done, now to decide which type of add’tl armor to use:
IMG_6670 by Russel Baer, on Flickr
And while I was playing with putty, I worked on the engine cover some:
IMG_6671 by Russel Baer, on Flickr
I’m pretty sure (random thought here) that I’m going to skip side skirts/armor, mostly because I spent as much time as I did on the suspension.
The 105mm gun tube is just to see what it looks like. I’m digging around for a 120mm gun, go big or go home.
What about a 125mm gun tube? Eh? Nudge, nudge.
Well, to pick the nit, 125 is a Russian gun. I am however in the process of adapting a 120mm gun (from a Trumpeter Abrams) to this one, reason being the Merkava 3 and 4 both use it, so ammunition would be shared. I think it’ll work.
I know it’s Russian, but it’s big and long and it’s your build. I just figured, why not? Lol
Ohhhhhh, bustle rack and mantlet cover look good!!! [Y]
T’anks!
So, here’s a question: which of the three following gun tubes look like they belong? Each is a 120mm tube, two from an Abrams, one from a Leo2, main differences being the length and composition of the bellows/dust cover. The Leo tube has my attempt at duplication the rough finish of the fiberglass cover on the evacuator, other two are pretty much straight out of the Trump box, except for the bellows and different additional dust cover. Let 'er rip!
IMG_6673 by Russel Baer, on Flickr
IMG_6674 by Russel Baer, on Flickr
IMG_6675 by Russel Baer, on Flickr
Remember, I’m asking for opinions, no logic or reason needed. Of course, I’d like to know any reasons for a particular opinion, but it’s not required. So cast your chicken bones and post up.
I like the Leopard tube. It just looks like it belongs more than the Abrams gun tubes. It looks a bit more rough and I think that lends itself to the build.
I dunno! I like 'em all!!! [:(]
Okay. I’m off to glamp for a few days, got time to ponder. I my self kind of like the shorter of the two Abrams tubes, only because I did a nice job (I think) on the bellows extension, but the Leo tube is a strong second, with its irregular bellows. I chucked the tube up in my cordless drill and used a #11 blade as a bit, and it worked, looking more realistic then the others. Okay, off to the RV park for me!
I went with the Leo tube, after adding a collar on the mantlet, partly for visual interest and partly because I thought something would have to be done to adapt the 120mm tube. Mounted:
IMG_6677 by Russel Baer, on Flickr
And while I’m still diddling around on what commancer’s cupola to use, I did add a skate ring for the loader’s MG, out of the Takom Brave Tiger kit:
IMG_6678 by Russel Baer, on Flickr
I was looking through the stash, thinking about supplemental armor, and I realized I have a considerable amount of the ERA tiles from the Academy and Tamiya M60A1 Rise/Passive kits, got me to thinkin’…
Looks good to me. [Y]
Hey, Russ. I’ve gathered a few bits and pieces together. Looks like this lot will get me a good start for my frankentank.
Look what you’ve inspired lol.
