I am planning on building a Tamiya M577A1/A2 and would like to do some detailing (this would be a new effort for me). I’ve heard that Eduard used to make a photo-etch kit for it but I can’t find anyone that has one available. There are a number of 113 detail kits out there, but not sure which would be the best given my subject and experience level. I also saw a posting that talked about 113 interiors included in some kits. Would those also work for a 577? Any recommendations as to after market kits that would suit me best?
The M113 details will work only for the front part of the hull, the exhaust, the headlights guards and the rear door handle, that are the parts the 577 shares with them. Personally I wont buy them if I’m not planning to build an M113, 'cause the most part of the PE set will remain unused. If you plan to build a 113 then you can buy the set and clone the parts you need for the M577 “cloning” the cutting parts you need cutting some copper foil or aluminium can (the one from soda, cola, and so on)
Ciao
