Well here’s my entrance into the dark side of the forums.[6]
This is Tamiya’s 1/48 M4A1 Sherman. Being built OOB. I did scratch build the turrent interior but couldn’t get a good shot of it. I airbrushed the tank OD first, then airbrushed my own mix of white and light gray. I then took an exacto knife and started scratching away.
The weathering was done by taking real dirt and wetting it. I then applied it liberally to the lower hull and the bottom of the upper hull. When that dried I dry brushed Testors Flat Tan paint to give the look of dried mud.
I still have some touching up to do but other than that it is pretty much finished.
Well here’s the finished picture as promised. [cmra]
I added an antenna but it popped off just before i took the pictures.[:@] I added a second strap to the rolled blanket on the side of the turrent, and did some highlights to it.
Welcome to the darkside! Nice job on your first…many often wait a while before tackling a whitewash scheme but you’ve jumped in with both feet and produced a solid result. [Y]
~Bill~ Thanks. It sure wasn’t easy. I had to redo the whitewash 2 or 3 times before it got the look I wanted. After the “practice”[:D] I finally got the right look.
~Gamera~ Thanks. Really appreciate it. Thats how I was hoping it turned out.
