The tank’s turret has been completed. I will now be focusing on the tank’s commander’s copula. Once the copula is completed the tank will be off to painting [:D]
The turret lift hook bosses were fabricated. The way the bosses worked was the tank would have three eyelets screwed onto the three boss locations. Lift hooks and cables were then connected to the eyelets and were lifted by a crane lifting the turret. The same system was also applied to the M3’s commander’s copula. This system was replaced on the M4’s with three large lift rings.
A Large blister was added to the lower right hand side of the turret. The blister was made from using one of my Resin Panther track aligner.
The rear visor was added and is also functioanl. The surrounding area was built up with epoxie.
Enhanced cast texture was added to the entire turret surface.
The tank’s 37mm turret gun and mantlet were completed and installed.
For the mantlet I reworked the kit supplied resin mantlet. The kit supplied mantlet is a solid cast resin component that is nicely shaped and detailed. The kit mantlet is not designed to elevate.
To make the gun elevate I first needed to remove the molded in sections for the gun, and the optic drum.
A new 37mm mantlet drum and optic drum was created. The optic drum and 37mm drum are connected to each other with a single aluminum shaft. The shaft is mounted to the mantlet. This allows the drums to spin freely and in sync. An extension spring was added to help with barrel droop. The molded in fasteners were replaced with real slot screws.
A well was built to the lower portion of the mantlet where the gun drum recess is. This well is present on the real vehicle.
I have also added the M5/M6 37mm Gun barrel to the product line.
http://eastcoastarmory.com/ustankparts.htm
The 75mm Optic slide was also built and added to the 75mm turret drum.
