M270A1 MLRS Maintenance - Done!
My latest build is of a US Army M270A1 MLRS launcher undergoing maintenance.
I am starting with the excellent Trumpeter 1/35 US M270/A1 model (01049).
I will be building it with the cab tilted forward showing the engine, transmission, fan, radiator, etc. I will be adding the engine, transmission, radiator fan, and other engine compartment parts from the Meng M2A3/M3A3 Bradley interior sets. It will look something like this.
So far, I have started by cutting the floor of the cab out of the larger plate that also makes up the forward parts of the fenders that go over the tracks. I carefully cut the floor plate out and then cut away the rear section behind the notches where the rear wall connects. The area with red "X"s below can be discarded. Next, I cut the rear and side walls of the cab off below the raised line with bolts. I discarded the cut off part.
I also boxed in the back of the cab that is below the bolt line. There is about a 1/4 inch of the back wall exposed that has to be covered up.
Next I prepared the hull and rear engine cover. I added torsion bars to the hull and the Meng final drives. I also added a boxed in fan below the air intake vent.
Here are the Meng engine and transmission. I had already taped up the transmission for painting. Surprisingly, it only took a little bit of trimming to get the Meng engine and transmission parts to fit in the Trumpeter hull.
Here are a few of the other parts. There is the Meng radiator fan, a hydraulic reservoir, the air cleaner box (made from an M60 side-loading air cleaner), and the removed shift console.
I am currently painting all the parts up and will install the engine/tranny and all the other parts soon. More pics later.
I will be following your progress on this build Gino. The cool thing about these Forum builds is they are like virtual workshops for modelers, where we get to see how and why things are done the way they are by other members.
Harold
Oh cool, thanks Gino- neat ‘under the hood’ as it were demo!
Thanks guys. It has been fun so far. I hope to have some more pics of it all painted and installed soon.
Looking forward to seeing more progress, thanks for sharing.
Thanks GreySnake.
Work continues. I have pretty much completed the engine compartment. I just need to add a few decals and run a few wires here and there.
Here is the rear engine cover with it’s fan and shroud for the radiator in the center; fuel filler pipe, and air cleaner and intake hose on the right.
The lower hull with the engine, transmission, intake fan, and battery box. If you notice, the whole shift tower is attached to the transmission and does not pivot with the cab. There is a square cut-out in the cab floor that this fits into as it closes. You will also see a rod and gearbox across the front of the hull. This is the cab lift mechanism.
With the rear engine cover in place.
This is how it will look with the cab in place.
More to come as I move on to the cab interior.
Loving it, Gino.
Don’t know a lot about modern military vehicles, but this build is looking very impresive mate.
Gino, are you doing this from memory or do you have photographs and drawings to work from? Are you planning to have a technician working on the equipment?
Harold
Thanks guys. I am enjoying this one.
Sarge, it is a little of both. I do have some TM pages and other referances to fill in what I don’t remember. I do remember quite a bit since I worked with MLRS launchers off and on for about 8 years. It is amazing what you forget though.
I am alway amazed at the level of detail and customizing you do on a model. It is fun to watch you work through a project. I read some place you have been building scale models for 40-years. I believe you learn a few things in that much time.
Harold
Hi Harold. Yes, I have been building pretty much non-stop since I was a kid and I am pushing 50 now. I have two older brothers who built cars and planes and of course, I wanted to do what they did. I guess I have picked up a few things over 40 plus years of building.
That looks great!
You just need a mechanic figure!
The work on everything in the engine compartment is very impressive.
Thanks guys. A mechanic is planned…eventually.
I am still plugging away at the build. I have completed the cab interior. I added a few parts from the Royal Models MLRS Update set.
From it, I used the seats with seat belts; hoses and filter apparatus for the NBC system; and a few other smaller PE and resin parts. I also added a fire extinguisher from the spares box between the seats and a HALON fire extinguisher on the left side of the front wall. The rest is from the kit, to include all warning placards.
Here is the completed cab interior.
Next up is the completed engine compartment with placards added and weathered. I also added a HALON bottle on the front right as well.
Cab doors and the side engine compartment door interiors.
I have also completed the LLM (Loader/Launcher Module). I added the internal lifting hook/hoist mechanism that attaches to the rocket pods from ones left over from a Dragon M270 kit. For some reason, Trumpeter deleted these. They are needed if you do not have the rocket pods uploaded. They are hard to see, but they are in there. Trumpeter has all the other internal parts included and nicely molded.
You can see the internal hook/hoist mechanism in this pic hanging from the cables below the booms, just above the rocket pods. These hook onto the pods to lift them up onto the booms, then the booms retract to load them into the LLM.
The LLM overall.
Lastly, I will be adding the APU, A/C unit, and weapon mount from the Dragon M270A1 kit to make this a pretty current M270A1.
I am planning on making it a vehicle from 6-37 FA (MLRS), 2ID in South Korea in NATO camo. It is just about ready for paint. More to come later.
Good morning Gino. Fascinating the way you break down the components of this model. I have only recently started to learn some of your technique. One I noticed today is the way you paint the seats with shading you create what looks like real material. I love the HALON fire extinguishers. Hand painting, adding wear and weathering to the interior, engine compartment and LLM in modular approach you have much greater control over the interior detail. That makes a lot of sense. I started using your method on my M109A2.
By the way I received a second AFV Club M109A2 and M109 L23 to make an M109A1. It will also have that cool resin engine you reviewed. It may be one of the few M109A1 models ever made. When my M109’s are finished I will have the first three versions in the series.
Great work on your MLRS and good lessons for interior modeling.
Harold
That interior looks incredible- really nice work there.
And interesting, I’d wondered how you loaded the rockets into the thing- I had no idea they came in a pod that was loaded as a unit.
Thanks Harold. I’m glad this build is helpful to you. I’m looking forward to seeing your M109A1 build. It should be nice.
Thanks Gamera. Glad you learned something about the MLRS as well. Another MLRS tidbit; the slang name for the M26 rocket pod container is “Six Pack” since it holds six rockets. Too bad it isn’t six cans of beer. [;)]
Fine work so far!
“Six Pack”: neat, send a sixer to a bad guy.
Man, those placards really add the details to the kit. Your attention to all the bits is amazing. I love the work.
BK
