M1A1HA Abrams
I’m working on a m1a1ha Abram right now, and i was wondering if anyone had any pitchers of the anti skid and how far it gose on the tank, both the hull and the turet as well. Also does anyone know how to drill the holes in the drive sprokects and make it look nice as well?
Here is how the hull looks.
I did it with Rustoleum Terra Cotta texture paint. Simply tape off the areas without the anti-slip coating, spray the rest. Turret is also done in same manner, basically all flat, upper surfaces should have non-slip coating.
For the mud release holes on the sprockets, they are oval openings centered about half way from the outer edge of the sprocket and the center line where the two halves join. There are four of them. Best bet is to draw them on as ovals and then drill a hole in the middle of each oval. Carefully take a hobby knife and make the round drill hole into the oval shapes. Hope that helps.
Thanks, that help out a ton.
