Great Models sells a M.A.S.H Tent.
It is listed on the page that contains 221-240
GLW
GLW
Actually the inside of the hospital bus and ambulances on the show were OD green I believe. If you have the Hallmark channel I believe they have been rerunning the series in syndication for awhile now!
Ben
hello Vasser 13 ,
I’ve been on other projects… I found two italeri 1:35 No.226 Ambulance models at my local mom and pop store…I run accross them from time to time … I only purchsed one … and ran into a alignment problem with the front cab/rear top section… I uesd.020 by.040 styrene to blend it in…
on the progress, I bought an older mash tent by VP #203 mash tent. I chose to make the second tent a liner. The MASH tent the outer … by combining to two. I made the frame. in scale 2x4’s , fit the VP #203 to the frame. With the MASH tent as the main exterior.
So… making the swamp…itself I chose to slice the tent from BJ’s corner to Winchesters corner focusing on Hawkeye’s location with the “still”. here is my problem… in scale. i made the boxes and cabinets.
I have a globe (from a back to the future item) plastic to cook the ingredients and copper wire for the condenser.
but … the glass / glass wear & frame work did they use.
dose any one have ideas on how to build them?
