M-18 troubles
Hey,
I am currently building the M-18 Hell cat made by Academy in 1/35 scale. When i put the upper hull on the lower hull gaps form on the front, near the idlers and the rear of the tank.
I want to fill this in, but dun have any filling in stuff [?] so i was wondeirng, if anyone has ever made some homemade gap fillers. If so, what did u use to mke it?
Cya
why dont u just buy a gap filler. Testors Contour Putty is only like 3$. you can also use super glue for small gaps. drywall compound could be used if you are very carefull! but, i highly reccomend that u use Testors Contour Putty its cheap and youll use it more than once![:p][:p]
