Luftwaffe airfield equipment
I am working on the 1/72 AMtech Ju-88 Mistel and have gotten a potential diorama bug. iSince the kit has all of the parts for a regualr Ju-88 and the Mistel nose, i thought that it would be cool to attempt a diorama of changing the nose. From what I understand it was a fairly simple bolt-up oreation to replace the nose with the bomb.
What I am looking for is any sort of reference as to what kind of trailers, tractors and such the Luft used on bomber fields. Would they have used a jig pole, or a tripod or a crane to lift the parts?
Web links or print reference titles would both be helpful.
Roman
There are some Mistel pics here that may be helpful. Not much in the way of equipment, but you can see the setup.
http://www.luftwaffepics.com/lmistel1.htm
Hope this helps.
www.matadormodels.co.uk has a selection of Luftwaffe ground vehicles, you might find something of use there.
Over and out
Pixelator: Thanks for the link. I have seen most of the Mistel pictures before but some of the stuff on the rest of the site, WOW!
Harrowbeer: It looks as if I might be able to find something there. If not for this project , then for one of the multitude down the line.
Thanks, all,
Roman
