Finally I have found a product I really like. I am curious to see if anyone has had any adverse events with this. I have been using Tenax-7R the space age plastic welder as it says on the bottle. I LOVE IT!!! It is a liquid and flows, I mean flows in between spaces, hold for 10 seconds and wallah, bonds wonderfully. No fumes, noirritant on the skin that I can tell. If you get it between your finger and the plastic, you are not welded to your armor. This stuff really works. The bottle will last if you continue to cap it. If you keep it exposed to the air, it will yellow and evaporate. The price in Ky is 3.99 for 1 fluid oz. Try it, you will like it. I have also used it to spot weld canopies and have not had adverse clouding, you know what I mean. Also, I use a single applicator brush which does not get stiff or anything. The cement or whatever it is must evaporate off the bristles, I have yet to clean it. Pitch those toothpicks and glue applicators, this stuff is great. I have only used it on 1:35 armor, will be anxious to test it on aircraft.
Yeah, alot of people here like Tenax. However, it can evaporate, so close the bottle tightly.
yeah, Tenax rules
