Looking for Tips on Tire Lettering
Does anybody have some tips or tricks for painting the raised white letters on tires? I tried using a brush, but the finished product looks bad. I am trying to find a better way.
I’ve heard lots of methods, but there’s only a couple that work for me:
  1. I use a piece of white chalk pastel that has been sharpened in a pencil sharpener. You can pick out the lettering quite easily, and any mistakes can be wiped away with a brush dipped in alcohol). Blow the dust off and then spray with flat-coat overtop. This method gives me the best results.
  2. I’ve also had moderate success by putting some white paint on an index card or a post-it note. I then ‘dab’ the raised lettering in the white paint. It’s a bit of a hit-and-miss technique, but when it works, it works fairly well. The biggest challenge is getting the right amount of paint onto the card. Too much will just make a mess and too little won’t leave a good impression.
  3. If you’re trying to paint the letters in with a brush, I’d suggest a couple of things:
    a. Use a magnifying glass of some sort. You will have much more control.
    b. Use a brush that has long, thin hairs (I think they’re called ‘liner’ brushes?). They hold a good amount of paint and really work well for this type of work.
Good luck.
M.
I use a fine white gel pen. Works quite well.
Lee
I have had some luck using a Presto Correction pen with the fine point. This is liquid white out, when done spray an overcoat of flat-coat.
All good tips! I was thinking of trying a paint pen, but I don’t know how fine the tips are. I hadn’t thought about a gel pen or correction pen. The chalk sound like a good idea also. I’ll have to give some of these a try and see which works best. Thanks guys.
