Looking for Micro Tubing
Hello,
Does anyone know where I can purchase in the U.S. (online, preferably) Griffon Models Brass Hollow Pipe in 0.3 amd 0.4mm sizes?
I bought something similiar from Spruebrothers about 12 months ago. Stuff is so thin, I am not sure how to use/handle/cut it w/o destroying/collapsing it…
I know its not brass, but I get hypodermic tubing from a place called Component Supply Company.
You cut it by using a new x-acto blade. I have a piece of wood that i cut two grooves into at a 90 degree angle. You put the tube in one groove, measure the length you need and then cut it by sliding the x-acto in the other groove. Thanks for the info, I’ll check it out.
Did you check Micromark? They sell quite a selection of tubing.
Hope this helps.
Stay safe.
Jim [cptn]
Albion alloys carry a very extensive list of metal products.
McMaster-Carr is another source. I’ve bought fine gauge steel micro tubing from them, for gun barrels in 1/72, for antennas, etc.
This is their catalog page for steel tubing: McMaster-Carr
Another source is hypodermic needle tubes.
