Hi all, I was told to ask in here. I am building a 1/48 F4U-1D Corsair and I am looking for a Dio Base for it. I was looking for something that looks like dirt ground and maybe puddles of water on it. I hope y’ll know what I am talking about here LOL
Looks like you’re going to have to get creative. I’m not aware of any bases that would fit your needs. About the only thing I can remember having seen was steel plating that was used in the South Pacific, but I’m not even sure it was 1/72. The Celluclay/clear resin and a wooden base from Michael’s or AC Moore are about your only options. These stores also carry stuff in the flower section you might want to raid as well as the HO section of the LHS.
Here’s a cheap idea. Go to Home Depot or a tile store and see if you can find a 12"x12" or 13"x13" tile that would work. You should be able to find an unevened surface in an earth tone. Simply border it with some wood strips stained with your preferred color, and then pour Future into the appropriate “dents” and allow to harden. These may take multiple pours to get the desired effect as you shouldn’t add a lot of Future at a time. You can even tint the Future to make the puddles look muddy.
For dirt, look around the house, you may find some interesting fine sand and small rocks. For the grass, I guess your best choice is your hobby shop. There are some manufacturers that sells small fibers to simulate grass in different colors.
I wouldn’t use Future. It’s designed NOT to build up. Look how much detail stands up when appiled to a model, even the finest panel lines can still be felt. Go to the hobby store and get some Liquitex, a clear two part epoxy that’s designed to replicate water. Or go to the craft store in the decoupage section and get some clear epoxy decoupage sealer. It’s self leveling, dries clear and hard and each application build up several millimeters at a time.
That’s the product I used for the water in these displays.
