Where do you guys go online for your figures? I am looking like crazy for some 1/35 U.S. medics.
Check out both
www.squadron.com
and
www.greatmodels.com
sure there are some out there but I can’t help more then this. search under figures.
Only ones I can think of are old Italeri sets. There was one in US Marines set, and a couple stretcher bearers in the US Support Troops set. They were both old and pretty bad. Tamiya had a set as well that went with their Landrover Ambulance kit as well, also old and pretty bad. There are some in resin from Warriors and a few others that I can’t remember the name of. Check the above sites and they should come up.
Good luck.
slap some medics brassiards on the left arm of an inf. figure and you are well on your way.
WWII medics wore the same gear, with the exception of weapons to conform to Geneva Conventions. You can scratch stretchers with brass rod and tissue in the same time it would take to clean kit parts and they will look better.
thanks guys. I figure making my own is the best bet. I just figured scratch building the medic bags would be a pain.
I’m pretty sure Verlinden make at least a couple different sets with medics.
