Looking back at my mistakes
I was looking at some of my older models especially one which I consider one of best work. I started looking closly at the prototype( the real model that is), and noticed that were mistakes. Just by looking at the model you wouldn’t think so but small things like the gasoline tank pipe on both sidesof the tracktors are in the middle of the tanks as suppose to on the sides like on my version in pics.
But one really annoying difference, which I just noticed, stupid me[:(!]) was the height of the air intake and tool compartment on top of the lves tracktor. It is simply too low to that of the drivers compartment. (See pic with red circle).
well, i guess you learn everyday. well, I really can’t be bother to retify these mistakes. I just have to convince myself that it is still a great model and I should be happy that now I will be more careful in the future.
Then again, where does the limit end and where does it start? mmmmmm!
I will however still take it to shows and display but not enter it in any competitions.
The real thing:
My version.
It’s still a great model. It all depends what you’re looking for. If you wish your model to be as accurate as possible, the key is getting a hold of as many resources as you can before you start the build. If you’re allready full-swing into it, then notice the differences, it’s a little too late. Some build for fun, others are anal rivet-counters. Both have their place in the hobby, and which extreme you float towards is up to you. Personally, for me it’s a matter of fun, so if there are a few inaccuracies, I sure won’t lose any sleep over it.
Great build, and thanks for sharing.
Thanks for your comments. I did not have much resources to model from as usual when i built it over 3,5 years ago. I just came by these pics about 2 years ago with other detail ones and noticed these small mistakes.
I for one am not anal about every singel detail as other people. It sounds pretty rediculous to get every nut and bolt down to the right number and size. You cares if the nut is 0001mm off, but there are people who do and that’s good for them.
I still consider this model on of my best work but some of the bigger mistakes could always be avoided to get an overall accurate model.
what did you use for the mud on your wheels???
i’m looking to recreate that EXACT look on some of my NATO tanks
Tiking, thats a very nice model. I agree with zoki though. How many pictures of the prototype have you looked at? All that equipment that they throw together on those big rigs is all modular but not necessarily the exact same dimensions. As long as all the specs are fullfilled in the final vehicle at the factory is all that counts. Have you satisfied all the specs? Yes. Then your job is done [tup]
Thanks for the compliments. The mud was made with the real thing. Mixing dirt and water. I placed it on the tires and waited for it to dry. Then I used brown powder chalk to toned it down. That’s it Simple.
At thetime I only had the pics you see above. It’s only a year and half later I found others. I’m pretty satisfied with the end result except for the height behind the driver compartment… aaah well, you learn from your mistakes[:)]
more pics: http://homebuiltstabilizers.com/indexthumbnailgallery/index.html
Tiking thats is a great model so don’t go crazy beating yourself up over a few inaccurcies you now noticed after its completion.I"ve been down that path myself and found that the best thing to do is to set this model aside and start another project and apply your time and effort to it.
I agree with the rest. Its a great build and a beautiful model to start with. Dont kick yourself over some inaccuracy. Your next build will be better.
Tiking! You are beating yourself up and there’s no need to do that my friend, It’s an absolutely beautiful piece of work, and only the most discerning person would notice any shortcomings in the accurate details. Like some of the folks said here! The most important person is yourself and your satisfaction with what you have created. Keep up the wonderful work. Semper Fi, Mike
Thanks for all the support guys. Your’re really kind. Love the advice. :slight_smile:
I forgot to mention that.
Well taken. good point.
