I just bought revels 1/48 me 262 a-1 when i painted the aircraft and I painted over the canopy then i fogged it up for some odd reason then i tried to remove it and it split in half[#oops], so i looked for an aftermarket canopy with no sucess.[banghead]
does anyone know where i can find that canopy?
thanks
Any chance you can repair and restore the original?
Clean up, cement with liquid solvent, cure, polish, dip in Future, reinstall.
Surely Squadron has vac canopy for the 262.
Just checked no canopy listed by Squadron. Either it is out of stock or they do not make one. I do not know of any other company that makes canopies. Next step is to either see if someone has a spare or contact Revell for a replacement. Sorry for the bad news.
Soulcrusher
It probably fogged up because you used some CA (superglue) near it. Dipping in Future first usually prevents that. Falcon from Squadron seems to have made it in 1/72. I can only guess that the Tamiya 1/48 kit has such a good one they didn’t bother. You might try to find one of those.
Glue the broken canopy back together and stretch-form a new one using clear sheet stock.
