Lindberg JU-88 painting
I bought on e-Bay an old Lindberg JU-88 kit. OK, I know it is not the best on the market and do not tell me about all that flash; I bought it anyway because my father bought me one about 40 years ago and, believe me, in those times we were not so rivet counters and those moving surfaces, retractable gear and modeled engines were really outstanding! Now I need your help because I would like to paint it in a “correct” way, so I would appreciate very much if somebody could suggest proper painting scheme and colours, considerindg that the model is an “A” bomber version. Thanks in advance for any help.
Gianni [:p]
Wow! Such courage to face a Lindberg kit! [:p] Well, I don’t know much about Nazi paint schemes, but I’ve always wanted to do a Ju-88, so I’ll see what I can dig up. You may want to contact Pix, because he loves them german birds, or swanny because he’s built a condor. [:D]
For a JU-88A, the most common scheme would be the RLM 70/71/65 splinter camo. There were several other schemes depending on the Theater and time frame, but I won’t attempt to describe them all here.
Bueno… realmente no le hubiera recomendado un modelo a escala Lindberg… disculpa pero son realmente malos… refiriéndose al camuflaje… debe sel el cásico de los bombarderos de principios de guerra… RLM 65 en la parte inferior, y RLM 70 y 71 en la parte superior… aunque depende mucho del teatro de operaciones… podría ser también el esquema de desierto… RLM 78 en la parte inferior y RLM 79 con pequeñas motas de RLM 80 en la superior…
Hay zero, we use English. [:I][:D]
What did you say Zeroenna?
hey!!! cual es el problema de hablar español???[8D][8D][8D][:D][:D][:D]
rail49 you can go to the next link:
http://www.aircraftresourcecenter.com/
search in the photo gallery for JU88 A-4 and you´ll find one with the with the splinter camo
hope this helps…
I started one of those twenty years ago. I get it out every now and then with the idea that I might actually finish it with a few changes to the interior. It would appear to represent a JU88 A1 bsed on the canopy design. The scheme most likely would be 70,71, and 65 since that model was obsolete by the end of the Battle of Britain. Atleast, that is the scheme I still plan to use if it ever gets finished.
