As a bif fan of the Sd.Kfz. 222 I’ve had this one coming for some time now… It started many years ago when I looked inside the box of Tamiya’s kit - was very impressed, but I didn’t buy it then… Then there were the TV series “Allo Allo” - for the ones in the know - and then, much later First to Fight issued a 1:72 kit which I have bought right away. I started tinkering with it, but some details bothered me, so I started looking for PE to fix it and came to the conclusion, that the cheapest way to get it would be to buy ICMs kit (they wouldn’t sell me individual sprues). I ended up deciding on a kitbash of the F2F and ICM kits.
Let me post a couple of photos for a good start:
My goal is to build the 222 as it appeared in September '39. For that the ICM kit shows a vehicle that is too late. So I transplanted some of the F2F parts on the ICM kit - liek the lower suspension parts or that large storage box on the side of the vehicle, I also added some copper wire parts, as I like to do, and omitted the notek lights and made width indicators with white glue balls on their ends.
By the way - if anybody would like to share their 1:72 builds of vehicles of this family, they are more than welcome - we can have an informal group build, if you like.
For now - thanks a lot for your attention and have a nice day!
@pr154 - thanks a lot for your comment, nice to know somebody is reading that!
And I have another update - The model is tiny, so the construction is relatively speedy. I have put everything together, spending some time to detail the insides the turret a little - unfortunately that’s very hard to photogtaph.
Then I installed the ICMs PE and started painting - first I have painted the chassis dirt colour:
Then I put on some Panzergrau on top - I used the Hataka orange line paint. Plus some pigments and black wash:
I still have the fire extinguisher and the jack to install, maybe some stowage
It took me a log time, but I have finally installed the jack and did a little more weathering - and now the 222 is done:
Here I tried to photograph the insides of the turret - pretty hard to do. At least I know there’s something there - something better than both the F2F and the ICM offering:
The remainig photos of the 222:
And now I started two more: Sd. Kfz. 221 from F2F:
I have closed up the gaps in the floor and I have fabricated the rear wall with the radioator. Let’s see how much of this will be visible - probably not much.
It’s even more hopeless with the Sd. Kfz. 223 - here I “transplanted” sides from my unused F2F 222 hull:
As you can see there is already an opening in the roof where the PE mesh will go.
Let’s see where I can get from here - thanks for looking and have a nice day
That first example turned out really nicely! I can’t imagine anything other than PE for rendering some of those details, but you have applied them well! Are you planning to put the two 222’s together in a small vignette or dio?
Hello! Thanks a lot for your comments! @GAF - Thank you. The 221 in 1:72 is only made by F2F from Poland - and I alredy had it in stash, bought it when it was issued for an equivalent of 5$ @pr154 - Thanks a lot! Yeah, PE is really a saver here. No, I don’t want to put these models on a base - at least permanently - because I want to be able to view their underside from time to time.
I keep on working on the 221 and on the 223. As they both have the “small” turret, the interior has a small chance of being visible - so I’m working on the details supplied by F2F:
221:
Some of that might be visible through the mesh behind the turret:
223:
As in case of the 221 I have modified the MG base, so that the motorcycle seat it has is slightly offset to the left, like it should be. Additionally I have scratchbuilt a part that is supposed to represent the radio set as viewed from the rear:
Additionally I have designed and had them 3D printed for me the lower rocker arms of the early version (Horch 801 EG I):
Thanks a lot for your comment and for your kind words. I think on cars with “small” turrets some of that will remain visible through the turret and through the mesh on the aft deck - I think some people don’t appreciate how these babies require basically open top in order for the engine to get its air, mainly for cooling. I sure pity the crews having to put up with any kind of weather in a body like this… I’m also a little surprised how little info there actually is on these vehicles - and it is reflected on the models. Like the 223 is a radio truck - and it can be said that none of the scale models of it show it having any radio on board - isn’t it a little funny?
These look great! For such small kits, both ICM and F2F still appear to be quite detailed while still lending themselves well to your further improvements! I was struggling with the planning for a future project since the (gifted) base kit was quite sparse in detail, but not in a bare kind of way that you could add to. More like a process where you’d have to cut everything away in order to build up again.
Thanks a lot for your comment and for your kind words!
Yeah, sometimes you wish they would just ommit some features instead of moulding “a blob” in place - that would just save you cutting it off… That’s kinda what ICM did with the interior in these kits. Again, the F2F’s “blobs” are made for gaming and will handle abuse well while still looking quite good. Often you have to pay for a Dragon kit to get stuff like tools and fire extinguishers moulded separately - and Dragon doesn’t make the more exotic topics that F2F does. But I think it’s apparent that I like to cut stuff up
Thanks again and have a nice day!
Paweł
