leaf litter and hedgerows
Hello!I am currently constructing a diorama using some of those delightful Woodland Scenics trees. When I have glued the foliage to the tree trunks and set the trees into the diorama, I would like to add some tiny leaf bits, etc beneath the trees on the ground, as well as up on the tree itself, using what I can find. ( including perhaps some spices, bits of parsley, etc… from the kitchen cupboard.) Now, to hold this leaf litter in postion, would hairspray do the trick? Other suggestions? Also, to represent the bocage region of Normandy ( I have a King Tiger that would be ideal for this location ), would rows of Woodland Scenics brush and foliage do, or would a crumbling stone wall be good to add as well? If so, any recommendations as to 1/35 stone wall producers? Thanks in advance for any guidance you can give me!
Here is a small article about Normandy hedgerows, including a typical cross-section;
http://www.lonesentry.com/normandy_lessons/index.html
Many hedgerows also had stone walls in the core instead of just earth. Farmers would remove rocks from their fields and stack them into walls at the edges of the fields. Over the centuries, these would end up covered in dirt with the hedges growing on top of them, or sometimes just bare stone walls to be used as fences.
Parsley, oregano, basil and other dried herbs work well for leaf litter. Birch tree catkins, shredded apart, also work well. Hairspray will work to hold it down, but I prefer to use diluted white glue in a spray bottle. The herbs tend to fade in color over time, so I tint the glue mix the appropriate shade to prevent the loss of color.
