Königstiger nr. 233 in Budapest 1:72 Revell
Hi!
My second tank ever, I’ve builded it based on reference photo. Unfortunately, I couldn’t get right decals, so they are stock, but historically correct.
Zimmerit was done by hand, in Green Stuff.
Hope you’ll like it!
Holy crap, man. That is gorgeous!!
Seriously well done!!
[dto:]
Yeah,
Very much so. Great paint and weathering.
Very good job!!!
A mini masterpiece. Well done.
Excellent job with the Green Putty for the zimm. The weathering and color modulation are tops! Well done Sir.[B]
Tremendous work. It looks like its a 1/35 scale instead of 1/72. Great job.
Stunning work. Hard to believe it’s braille. Excellentjob on the zim and weathering.
Thank You very much! I am happy you like it!
Absolutely, all the above and more.
Thanks!
Your second tank kit!?! Wow, I buried my first five or so in a hole in the yard so no-one would ever see them!
Outstanding work! I too would have assumed she were 1/35th if you hadn’t stated otherwise!
Thats a stunning build, great job on the Zimm and really nice camo.
Yes, second build, my first was BT-5 from Unimodels, I have to post it here, but I am fresh user and have to wait to see my posts.
How, exactly, did you do the zimmeret? Amazing job! Very well done.
Thin Green Stuff. Pattern done with help of self-made tool from compass wheel. I just had to pick up wheel with right grooves and the rest was easy job. Just roll.
Stunning work,. to say it’s great would be like saying the Mona lisa is a good painting.
Great build! Especially for a second armor model. Also, when you say green stuff, do you mean the 2 part epoxy like kneadatite. The type you mix together and feels like playdoh. And if it was like kneadatite, did you flatten it out along surfaces of the tank, then use the roller over it?
Fantastic! I had scroll back … ‘did that say 1/72 scale’? Wow.
Yes, two-part epoxy putty called “Green Stuff”. I’ve flattened and put on armor. Then, I flattened it more rolling with small bottle or something similar, but round. When it was thin enough, it was time to make pattern. When Green Stuff is dry, you fan peel some off to simulate damage.
