Klingon Bird of Prey WIP
The LHS finally got some of these in, and I’ve been eager to try one out and see what Round 2 had done to improve the kit. This one’s going to be for display at the LHS with the intent of being practice and getting familiar with it for more detailed builds later, as well as a kind of “advertising” for the store ( letting potential buying customers see what comes with the kit ), so I’m restraining myself from adding what I’d otherwise like to for extra detail.
Right from the start, there was a problem. The upper part for the nose was flawed, with a missing area.
| photo IMG_0299_zps0ae35363.jpg |
But, that’s just setting up the difference between “assembler” and "modeler, right? I filled most of the gap with Tamiya 2-part epoxy putty, with the tube type to finish up.
While that was drying, I started work on the wings. After test-fitting, I used the darkest green I had for the areas where the interior plastic would be visible, a simple ( and, again, out-of-the-box with no customizing needed ) solution to the problem of bare plastic interior showing through.
Then the put together, primed, and added base color to the wing sub-assemblies.
Kugai,
That’s looking like it will be very sharp. I’ve never done a “modern” ST kit, only the old AMT ones. I might have to get one of those.
Paul
I started with Russian Marker Red for the underside plumage pattern…
…but decided it was a little off for the look I wanted. I ended up making a mix with Tamita red and orange acrylics, and after a few layers had the contrast I wanted. Yeah, it may look a bit bright, but there’s still the weathering phase coming up to take care of that.
Then there was the topside of the wings. This is where I also started figuring out what colors I wanted to use for the plating detail. The odd, more bright green section is one of the colors I tested and rejected, covering up with the final colors.
You are off to a good start.Gotta keep an eye on this one.
I actually have both of the earlier releases of this kit from AMT in the Generations boxing and these kits actually scale close to the Polar Lights Enterprise Refit.
Lookin’ good, Kugai!
What paint and color did you use for the green base color?
Are you going to build ‘er with the new-releases’ landing gear deployed? I have the old one, sans gear, and look forward to seeing what the additions look like.
Keep up the good work!
With Regards and Aloha,
Johnny B
Are you gonna light it up?
Looking great!
Thanks for the comments, guys.
Havoc, the base color is Testors FS Pale Green. Plating was done with Fulcrum Gray Green and Zinc Chromate green, also from Testors, after deciding against the Russian Interior Blue-Green and Willow Green ( tested in the upper photo of the topside ). The red plating is a 2:1 mix of Tamiya’s red and orange.
MrSquid, no, I’m not lighting this one. My goal here is to get familiar with the kit to make planning lighting a spare someday easier, and have something “out of the box” to display at the LHS so that people know what they can do without the extras to maybe nudge someone’s interest in starting the hobby ( which, if successful, would help the LHS stay in business longer ). The closest to lighting is I’m using a thin coat of neon colors on the inside of the engine with red behind it to allow a “fake lighting” effect if there’s a blacklight handy.
And now the bad news. While I had set the kit aside for a little bit, something happened to it that broke one of the domes loose [bnghead]. I’m not junking the kit, but I got another one ( all my old spares are made for the old stand, and I’d like to use the stand Round 2 provided for this project ) and am rebuilding the fuselage. The new fuselage will go with the wings I started, and the broken one will be reused for a custom project I have in mind. I’ll have more on that later when I post more pics here soon.
I too, had a malformed piece on this kit (although mine was on the underside of the rear edge of the wing), so kudos on fixing it–should be barely noticable.
My suggestion for the weathering–do an internet search. I don’t have the pic available right now, but I found a beautiful picture of the original shooting model (made for “Khan”) taken at the auction a few years ago.
I will be following this closely–might even start a thread so I can post mine side-by-side with yours[;)].
Keep up the Great work!
Klik
