King Ghidorah (Previously Sculpting Mouth and Teeth)
Sometimes the Modeling Gods test your mettle. I’m working on the new Kaiyodo King Ghidorah (absolutely fantastic kit) and lost one of the upper pallettes. Luckily I make Dino teeth whenever I have leftover Aves epoxy and was able to sculpt the pallette and add teeth. Think it turned out OK!
Can you tell the difference???
Rob, that turned out nicely! It’s those accomplishments that sometime make all the difference. Don’t necessarily wanna, but you do it, you feel good about it, and you know you could do it again. Great job!
Thanks Tim. I know you can appreciate this based upon your current Budweiser build. :smiling_face_with_sunglasses:
Solid recovery. :ok_hand:
Side by side there is a slight difference, but under a coat of primer you would be hard pressed to tell which is which. Once paint is on and they aren’t displayed next to each other it won’t be noticeable at all.
Terrific save, Rob!
Now, make some teeth for me. :laughing:
Woah - What is that???
Yep, slapped some paint on them and I’m very pleased with the results!
Actually, the new teeth look better!
The thing I am building is Machinegun Snake, an original take on a Kamen Rider V3 monster.
Bing Videos
Soon to be rebuilt with a proper M134 minigun.
OK - Now that is Awesome!
I hope to get this thing built by next year’s Wonderfest. I also hope to see your King Gidorah there as well!
We are mad scientists building mo~nsters! :laughing:
Cool! That’s the Plan!
Rob,
I can tell the difference…your teeth look better. I’ve been doing the same thing you do, using leftover Aves for something else. Much of the time, I use it to augment another model, even if I’m not working on it at the time - adding weight to the hollow feet of a vinyl figure, for example. If the Aves has gotten too stiff, I shape it into rocks and boulders with a piece of 80-grit sandpaper moistened with their Finishing Solution (formerly Safety Solvent, for the uninitiated).
Thanks Mark. I agree - they do look better, but I’m certainly not going to replace all the teeth! :slightly_smiling_face:
Oh, I wouldn’t expect you to, Rob - if for no other reason, to help differentiate between the three heads.
Update time. Got the kit assembled. The engineering and fit are incredible - barely any seam lines!
The amount of detail, especially for a styrene kit is insane! Assembling the bridge was probably the most difficult part - lots of tiny, fiddly parts!
Painted the base using various drybrushed acrylics and washes.
Upon further inspection, it appears there should be water under the bridge. Will have to address that…:face_with_symbols_on_mouth:
OK, calling the base done. Painted the water shades of blue and green.
I can’t imagine how you do that without overbrushing onto the rocks. Did you mask it off?
Mark
Nope. Water was carefully hand painted Mark.
Very impressive work, Rob!
Basecoated Ghidorah with some Pro Acryl Bronze.
