Ki-27 engine
How the Ha-1b engine (in Ki-27) should be positioned ? I have the Hasegawa 1/48 kit and there is no explanation or even a drawing of it ! My problem is - in which place cylinders shoud be mounted - I mean should I pose a single cylinder in the top or rather two of them in “V” shape ? Aleksander
The engine face has a small alignment hole under one cylinder. The plans show that hole at the top as you assemble the pushrods and crankcase to the cylinders. That then goes straight back to the firewall, with that one cylinder up.
