Actually if you want to check a compressors ability to keep up then that airbrush is a reasonable choice to do that with. So how do you like the compressor ?
This is the same compresser i use and i love it! easy to use, fairly quiet and easily adjustable. I would say the only drawback would be that you have to adjust the PSI everytime you use it but you should be doing that anyway.
