JUNK BUILD 3 FINISHED "IN SEARCH OF LUNCH"
Hoyhoy`al
This might be a continuation of the 1st junk build as basically the main component is the same.
Dont bother going searching for the original as Ive tidied up my images and the dreaded red cross is everywhere. and I`m posting relevant below.
!st Junk Build
The new build.
Basically if you take the top pic above
and turn the inhaler through 90 degress you get this
Well off to give it a blowover as a dent n ding check and will post more as and when,
All comments etc welcomed
Cheers Gary
Hoyhoy`al
Next batch, after adding a few bitz and a blow over of tamiya gunmental. a sort of walk round.
the last is a top view. As an impulse build I think this is working quite well, as is often the case with me and I`m enjoying it enough to keep putting down the serious builds to return to this. As always comments critiques and bills for damages read but mostly ignored,
cheers Drink
Gary.
That’s really cool. Whatever it is you’re using to build it lends itself perfectly to the smooth lines of a spacecraft.
I like the curves its got, and with the small add on parts it takes on a very nifty Art Deco sort of look. It would look even cooler with some chrome on it somewhere. I can hear it screaming for Alclad.
I’ve got no criticism except that if you do go with a metallic finish, it will be easy to see the sanding scratches.
Hoyhoy`al
After the last pics, a rub down with 1200 wet n dry wet and worst of scratches removed. Trouble is while one half of me was working out the next airbrush colour, the other half is three steps ahead and thinning down some black oils and getting a runny wash going. Next some enamel gunmental and silver dry brushed on bits. After the graphite powder came out I just laid back and went with the flow.
Obviously in the last pic the leg I broke off needs repositioning. Next a trip to London for some acrylic varnish to fix the graphite then some more washes and reentry scorching etc.
Incidently the base is in the process of painting for the Me109X build and the drums and cans are sceanic scatter for the spring clean build.
More as and if/when
Cheers Drink
G
Hoyhoyal Along with the 109s I`ve been fiddleing with this and made a few changes. The little bulges on the side have now become slippers on the landing legs and new bulges added as bustle tanks.
The cooling fins on the engine have been moved to suit and a little cleaning up and Im ready for final paint. In the past Ive tried the salt method to show worn paint but without much success, to going to try again with this whif wip.
Comments Etc as usual
Cheers Drink
G
Anyway here`s WIP 1/2 way through painting, hopfully looking like re-entry burns hurt and finished in as promoised very very off white.
Over the silvers I did use salt as promoised as a mask more of which later. After the salt and water had dried I blew over a coat of acrylic dark blue and painted on a liquid mask in wavy wandering lines. A word of warning, a friend of mine (friend?) gave me a bottle of Ameroid eazy mask as Im unable to get any Humbrol liquid mask locally. Reading the instructions it said I could cleanup with water which it did very well, the Humbrol mask has ruined more brushes than I care to count. Then I sprayed the model in black enamel. After the paint had dried I stuck the whole thing in a bowl off water and removed the salt wih a soft brush. Now Ive seen some incredible models ,usually of Japanese a/craft, using the salt method but for me it just dont work. It either dries as a lump or the chipped paint effect is just to small to be noticed, but at least Ive given it another go. The bottle of Ameroid states if the mask wont move try lifting with a wet knife blade. This wouldnt shift it either and when it did come away it took most of the acrylic paint with it hence the blue tints on the model. Anyway another lesson learnt. Well the next couple of days should see the painting done, and I think for a change Ill do a little dioand add a figure ![Grin|15x15](http://www.whatifmodelers.com/Smileys/default/grin.gif) Comments as normal and Im quite thick. (skinned that is)
Cheers Drink
Gary
Continuing with the modified paint job of yesterday, I`ve tried to give the impression of severe re-entry burn (As the Bishop said to the actress) with black paint mainly remaining on the top surfaces and panel lines with the filler burnt out. As mentioned a little dio base just 3 inches square, and now working on a figure and a suprise in the vein of Hitchhikers Guide etc.
And finally a view around scale figure height.
Now 300 people have looked at this and only one reply, what am I doing wrong [?]. Very suspiscious for this forum where the members are usually quite vocal. Comments are at least half the fun [(-D]
Enjoy, Cheers Drink
G
This stuff is so cool! I dont know why no one else is commenting. I really like how you can see a design in everyday stuff. I like your paint scheme here too. Your ships look cool, keep em coming. It must be really cool to show everyone unique models on your shelves.
I don’t usually browse this forum, but the title grabbed my attention so I thought I would take a closer look.
All I can say is WOW!!! That really is very cool. I really admire people like you who can look at an everyday object and see something else there. Truly inspiring. Keep it up, I’ll keep my eye out for your next one. [bow]
I just don’t think people have noticed it yet? I would also post it in a scratch build thread as it is pretty incredible! Weekends are kinda slow here too. I really am luving the metal finish and weathering. Are you coming up with a story to go with these beautifully rendered unique ships?
Maybe some Cheerleader aliens? [alien][party]
Man those are cooler than the other side of the pillow! They remind me of a Chris Foss painting.
Hoyhoy`al
Thanks for the comments, nice to know that there is people out-there.
There`s no backstory really to this one, just my excuse as below. I built it simply because there was a lot of scifi stuff going on on another site and I like the non specific style of scifi modelling.
"Its always puzzled me how in films, etc how their involved in an inter species war of survival, on ships armed to the teeth, but always eject to safety in an unarmed little pod in a bright colour with just enough fuel to reach the planet that they were fighting about in the first place. A sort of out of the frying pan and into the fire scenario. This model is going to represent an alternative to this. Its armed, maybe short life/range kinda weapons but at least some defence is an option in an genocidle war. It will be camoud to some degree and have the option of flying away from danger to a decent distance and the ability to land and lift off again. This should at least avoid the longest part of the film/book/backstory etc, of the boring saga of the trek to safety.
Oh well back to boldly sanding where no hand has set foot,"
or if you want the full build story go here
http://www.whatifmodelers.com/index.php/topic,21410.0.html
Cheers gary [8-]
Hoyhoy`al
Long time no input. Ive had brief visit to the old witch doctors at the Hopisotol, so no work done there, (they seem to frown on paint on the sheets, no sense of humour or priorities!). When they finaly decided I was going to carry on breathing regardless they let me home to find my puter`s 2nd hard drive had crashed and all my work was gone Angry,8 years of research on the net wasted, bloody AngryBang head.
Anyway this is something I started before lifes little surprises and if you only like long legs on women (or maybe men) dont look any further. Its built from some sprue, bits of brass wire and talcum powder in Johnsons Klear with some small ballbearings for the eyes.
The armature for the legs was thin brass wire bent up and added to a couple of pieces of thickish sprue for the body. the bumps and bulges were built up on the rough frame with talcum powder ( lavender flavour) mixed into some Klear and painted on, left to dry and then built up further to the required shape. A sort of slap on sand off in reverse. A dremel round router was used to make recesses for the balls and they were glued in. So another dio accesory built for peanuts from scrap.
All comments as per the norm,
Cheers Drink
G
ps The aforementioned peanuts are what I am now eating by the bucket load as an attempt to give up smoking.
pps Due to the general lack of feedback (which to me is more than half the fun off posting) go to here to see the finalised build in a few days.
http://www.whatifmodelers.com/index.php/topic,21410.msg312706.html#new
Bye All
I’m sorry this was commented on more. This is great! When I first saw that spider-type-thing i thought it was real. I like the flecks of blue paint, an overall excellent paint job.
I’ve tried my hand at ‘junk builds’ but they all end up looking like my toaster (where am I going wrong?).
Tell me about it! I found myself reaching for a can of bug spray! Outstanding work!
WOW! What an imagination! Good hands to, I’m jealous!! GREAT!!
Great looking diorama. I really like that bug creature. Your work makes me want to try something similar.
I know what you mean, most of my posts get one or two comments (usually I’m the second) but don’t lose hope. I’ve actually really enjoyed your junk builds and your spider creature made my arachnaphobia flare up so good job!
Very, very cool builds. I love the inventiveness on display here. This is what modeling should be about, finding innovation where ever you can, great work and I’d love to see more!
Having said this, I think its not the best thing to do to announce you’re leaving because there wasn’t much feedback. This isn’t the busiest forum on FineScale, and people may not visit for awhile. It does not mean its not appreciated. If you want a wrapt audience for these sort of subjects, you should try starshipmodeler.com’s forum.
Anyway thanks for posting these, and we’d love to see more!
You have your own Cylon? I am jealous [:D]
I still want to know if the critter is the pilot or just visiting?
