I built this for the Reich defenders V G/B ,thought some of you not tuned into the G/B scene would like to see my attempt at D5+AH Flown by Oblt. Herbert Koch april 1945 Grove Denmark NJG3
as always critiques /comments welcome Cheers Trey
Wow, what a beautiful build Trey! Awesome camo lines. Did you scratch the Schrage Musik cannons? Where did the decals come from? The aerial lines look perfectly placed!
May at least some of my. attempts come out that good! Beautiful
John
Nice camouflage work! Beautifully built!
Well done!
Beautiful work indeed! Does this kit have any build/fit issues I should watch out for? I have one in my stash…
That is just beautiful work!
That’s lovely work TREY. I really like the scheme, great job.
Beautiful build! Your camo job is excellent. [t$t]
Nathan thank you for the kind words . I drilled out the kit supplied barrels and the decals are from Owl.
John, Checkmateking,Mississippivol thank you all very much,appreciate you taking the time to comment!
Stikpusher thank you. Fit issues are minor ,to avoid an ugly step glue the wing tips to the wing halves before ,instead of glueing the halves together then adding them to the wings. This also works with the front fuselage halves.
Andrew ,Bish ,Mike thank yo all for the positive comments ,much appreciated!
Lovely, just lovely! Well done Trey, a beautiful model with a great paint job.[:D[
Gary
I can’t say it enough. Awesome build.
Totally agree on the build sequence to avoid steps in the wing and fuselage.
Just curious, anyone know why the underside of one wing is black and the other grey? Very nice build, it looks great!
Groot
Gary thanks
TJ thanks ,forgot to give you props for the tip on avoiding the step, thanks again!
Groot thanks,from what I was able to find the wing was painted black to avoid friendly fire
Makes sense, thanks!
Groot
Incredible work Trey. That camo job is fantastic. What’s with the Spitfire-like black wing?
Joe. I just read an article that in 1944 all night fighters were to have the starboard wing in black to aid in identification for flak
