Am building a 1:48 diorama of a F-14 at launch off a Nimitz class carrier. Need details on jet blast deflector,shuttle and deck markings. Any help would be greatly appreciated. Already contacted USN got no answer.
Thanks
John
Thanks
John
Did you check the carrier photo archive at NAVY.MIL http://www.navy.mil/view_gallery.asp?category_id=10
When you’re finished there check their archive on aircraft. Then check the Defense Imaging Command http://www.defenseimagery.mil/index.htm
You’ll probably find more doing your own footwork than relying on an already overworked PAO
Which kit are you using the Hasegawa kit? Because at least the Hasegawa F-14A kit has the option for the “Cat crouch”.
Thanks for the info
I have a blueprint of deck section with Cat and blast panels in 1/32 scale. Overhead view only.
http://www.navy.mil/view_photos_top.asp - This is the photo section of Navy News. Pretty much anything you could want of aircraft carriers, catapults, catapult shots, etc. It is searchable and some of the high resolution photos are quite good. It can take time to load, though, even with a high-speed connection.
The JBDs and Shuttles are all the same. It depends on which of the 4 Cats you are modeling for the deck markings.
No. The JBD on the #4 waist cat of Nimitz-class carriers is narrower.
Mark
Check this site out!!! There is everything from modeling carriers and dios such as a launch. This place is pretty damn amazing! http://www.carrierbuilders.net/
Type in the Search F-14 tomcat.
look for the modeler Masa Narita. He has a breathtaking 1/32 Tamiya Tomcat. Which I think you will enjoy!
Good luck.
