Jagtiger zim?
Hello all,
I have started working on my Jagtiger for the TD group build and have a question. would the Henshel production type Jag have zimmeritt on it? I’ve seen JagTigers with zim, but wasn’t sure if only certain type of Jags had them. the model I am working on is the Dragon Jagtiger #6050. Thanks!
Hello!
I believe only just a few of the early Henschell production had Zimmerit.
Late ones did’nt wear any, that is certain.
So it depends of what you want to do. You can go with the late ambush camouflage, with blowing leafs. I think they were the best looking ones. [}:)]
Yes it just depends on what you want to build early jagdtigers wore the zim but late ones did not so its up to you personally I would put the zim on it
leave the zim off, make it KISS
Pretty sure that the few Porsche types did, and like mentioned, a few of the early Henschel versions. Zimmerit was halted in the fall of 44. With a Henschel version, you can pretty much make the call yourself.
okay great. thanks for the helpful info everyone. I think I’ll go with the zim for my Jagtiger. I picked up a zim set from Atak, hopefully it will turn out well.
A good choice if it looks anything like the Tiger I that I saw.
