jagdtiger info please.
i have just got a dragon jagdtiger,box says late production.
they do one what says sd.kfz.186,but could not find this one.
the only etched set i can see for the jagdtiger says for the latter.
what is the differance in the two,would like to get a eduard barrel also.the etch kit is for the revel kit would this be ok.i thought i read they are the same kit.thanks.
gazza.
Gazza
here is a site that gives some details on the production of the Jagdtiger
http://www.achtungpanzer.com/pz12.htm
Aber also do an etch set for the dargon sd.kfz 186 (ABR35041)
Here is a picture archive that also may help with your kit
http://pictures.panzerworld.net/PzkpfwVI-Jagdtiger/
Hope this helps
thanks dave.
the Early Jagdtiger was the one with the Porche suspension,
then they ahd the Henshell Suspension ones later on and the late Jagdtiger had a machine gun on the engine deck
theres a Porche Jagdtiger at Bovinton tank musium England,(the only one left)
and theres a Henshell Jagdtiger at Aberdeen proving grounds US and at Kubinka Russia
try http://www.jagdtiger.de/index2.htm?http://www.jagdtiger.de/GermanTanks/PzIV-01.htm for photos of the Kubinka one
the Eduard barrel would fit as the Two Dragon top parts are the same and so is the Revell kit, and the Etch kit for the Revell kit would/should include the engine grills other little bits that you get with the Dragon kits
Gazza
The only difference between the Revell and DMl jagdtiger kits is that the Revell kit has sideskirts and lacks the pe set that comes with the DML kit.I used the Aber grill set on mine and the Eduard aluminium gun barrel.I’m very pleased with the gun barrel as it seems to be scale length and looks good,the Aber grill set is superb and sets the model off nicely.
HTH
Pete
thanks pete. i am going with the eduard barrel,i will have to see what etched set i can get hold of eduard or aber. once again thanks for for all the help all.
no problem for the help Freefall you dont have to thank me[:)]
