I am going to purchase an Iwata DA. I am starting with armor models, and feels I might as well get the best while money is in my pocket. I would appreciate any recommendations for this type application, pros and cons. I am starting with an 1/35th M1A1 tank. Also, pros and cons on using canned air to begin with.
You are going to get a million different opinions on Iwata vs other Air burshes. There are plenty of other threads that cover that issue. Sounds like you have made up your mind on what you are getting, but I will tell you that if you are planning on doing a lot of air brushing using can air will get expensive real quick. For what you are going to spend on cans you can get an inexpensive compressor and will be much happier in the long run. Good luck with your search.
Tanx Hercmech. Was hoping for just Iwata responses, but I’ll listen up for other brands too. Just planning on the canned air till I reload my dollar gun.
I’m not an Iwata guru, so others can pitch in on that.
As for canned air, it’s only pro is that is cheap when starting out, but as time goes by it’s price advantage starts to diminish pretty rapidly, most other things about it are on the con side of the coin. It’s pretty handy if you are investing in a very cheap set-up to figure out if you like the whole airbrushing thing, but other than that it’s a non stater.
You may find that after investing some decent money on a good airbrush, that canned air will let the whole set-up down drastically & won’t give you a fair impression of your airbrushes or your own capabilities.
To be honest, when looking to purchase an airbrush set up (whatever end of the market), you will generally be looking to spend the same or more on a comparable compressor as you will on an airbrush…
I hate to sound like a broken record but give Badger a look. I have an Iwata, Grex, Aztek and Badger. They all function about as well as each other, but the personalized customer service you get from Badger is second to none and they are significantly cheaper, so you may be able to afford the AB and a inexpensive compressor.
I have heard that about Badger, and did use them about 20 years ago, but never liked the feel in my hand. Heard many many good things about Iwata, and the slim line appeals to me. Looking at the Eclipse series. Canned air will be for a very short time, I just wanna get going before I go nutz sittin around. Retirement is fun.
If you are set on an Iwata and have access to Hobby Lobby, print out the 40% off cupon and use it there.
If you are looking for a slim AB look at the Badger renegade velocity, or even the new Krome. very slim and has a .021 neddle for fine work. There are a couple of threads here about them. Here is one.
Again not trying to sway your opinion, but when a company does right by me and I beleive in and have used their product I feel that I need to let others know.
i been using the paasche talon for about three months with no problems. kit came with two needles and two headsets along with a hose for an OK price.
i recently picked up an iwata revolution CR for $70 at local hobby shop. i’ve only done test runs on paper with acrylics and i find it much more easy to clean then my talon and the trigger has less resistance.
they are both awesome but im leaning more to the iwata because it has a better feel.
don’t bother with air propellant. you can get an harbor freight compressor with an water trap for about $60 bucks.
Iwata is great. I prefer this over any other brand, just excellent to use and maintain. Don’t bother with Badger. If you are only going to use cans for air then don’t bother. Wait until you can get an Iwata airbrush and an Iwata compressor. You will be better off.
just because you don’t like badger doesn’t mean he will. all the companies listed make great products. it all comes down to what you like and personnel preference.
Have you had a problem with Badger? I have several, and they all work fine. Iwata makes good airbrushes too. So do Paasche, Harder & Steenbeck, Dagr, and Grex, I understand.
I’ve had 3 badgers, 100(?) 200 & 150 in that order, they are also ranked in (by me) in that order.
I now have an (entry-level) Iwata CS. This is (IMHO) a level of magnitude better for these reasons:
Rolls-Royce quality, for a Rolls-Royce price though, but for what I paid for no.2 & 3, plus spares… I could have bought 2 CS’s…
Way easier & nicer to use.
& cleanup is a breeze, significantly so.
I also still have the 150 & 200 as backups, but yea, get yourself a compressor, pfreferably one with an airtank & 'fridge-type silent motor, & as ever you do get what you pay for.
I stand by my comments that Badger has really stepped up their game.
For those of you that have only seen their older AB’s have a look at the new stuff, like the Renegade series. Very nice brushes! Also the Sotar series are sweet too…pricey but sweet.
