No. Why would you want it on the top? If you want a gravity-feed model then look at the Badger Omni line such as the Omni 4000 and 5000.
The Anthem 155 will spray just as fine as the Revolution CR and BCR do, and possibly even finer.
Yes.
Yes. All double-action airbrushes that I am familiar with have adjustable trigger tension.
I don’t know what you mean here. All Badger and Omni airbrushes fit the same airhose.
Iwata has their own airhose and they don’t fit the Badger airhose.
Yeah i am excited to join up, dont worry i will be careful, i am doing reserve, i joined Force Recon Reserve Unit so i think that could go pretty interestingly… Thanks for your concern, I am curious as to how your experience in the Marines went?
Unscrew the handle and remove it. Then look at the knurled barrel sticking out of the back of the body of the airbrush that the needle exits from. This is the trigger spring adjuster. If you turn it clockwise it will increase tension.
It is part #T612 in this schematic:
You could call the place online that is selling them and get a total cost for it and then go get a money order and buy it that way. It’s up to you of course.
