Iwata HP-CS or Badger Patriot?
Nice. This was done freehand with the Badger Omni 4000 which is about equal to the Patriot.
The exhaust stains were airbrushed freehand as well.
Great Skyraider!! What did you use for the exhaust stains? Those always give me trouble.
nozzles aren’t interchangeable on the CR and CS. they both have a different thread pitch. yeah, weird.
You are right that the Revolution HP-CR and Eclipse HP-CS parts are NOT interchangeable.
You can use the Eclipse HP-BCS parts to convert the HP-CS from 0.35 mm to 0.5 mm needle/nozzle. You need the nozzle cap (# I 601 1), nozzle (# I 604 1) and needle (# I 617 1) to complete the conversion. I got all three parts for about $18 at Hobby Lobby. There are different between the two Eclipse nozzle sizes, but the difference is small compared to that between the Eclipse and the Patriot.
Interestingly enough, the Revolution and High Performance series needles ARE interchangeable. Cyrus Tan published an article on converting the HP-CR to 0.3 mm tip using the High Performance Series HP-C+ needles for $30. The nozzle and nozzle cap are from the Revolution BR. The article is still on the Iwata-Medea web site, but you cannot nevigate to the article from the site index anymore. I wonder why?
Yeah it’s the BCS/BR parts that work on the CS, then, I think…got the swaps over a year ago so I’ve forgotten since then.
That was thinned Model Master Acryl believe it or not.
